How to fix Bluetooth connectivity problems in macOS
Are you having trouble pairing a wireless controller or input device? Try this!
It happens. You've purchased a new Bluetooth-based accessory, and no matter what you do, it doesn't connect to your Mac. Whether you're trying to connect a new keyboard, mouse, or gaming controller, the steps below should resolve Bluetooth connectivity issues once and for all.
Please keep in mind this fix will be a reset of sorts. All of your currently connected devices will lose their connection and must be re-paired. So if you use a Bluetooth keyboard and mouse while performing these steps, you will get disconnected!
How to reset your Bluetooth configuration
Before you hop in, be warned that you'll be using the command line interface with elevated super user privileges and any mistakes can cause your system to become inoperable. Be careful to accurately follow these instructions.
- Start System Settings on your macOS 13 Ventura device.
- Select Bluetooth.
- Toggle off Bluetooth.
Using Terminal
There are two approaches you can take to reset Bluetooth next. The first involves using Terminal; the second requires deleting a file.
To use Terminal:
- Open Terminal.
- Type:
sudo pkill bluetoothd
- Hit Enter.
- Type in your user's password.
- Hit Enter.
After this, any device that has already established a Bluetooth connection to your Mac should be reset. From there, you can once again try to connect your missing device.
If this fails, you must perform these steps:
- Open Finder.
- Next, click in the menu bar Go > Go to Folder.
- From there, Type
/Library/Preferences/com.apple.Bluetooth.plist.
- Press Return. Once you do, you'll see the necessary file highlighted.
- Drag the highlighted file to the Trash.
- Empty the Trash.
- Reboot your device.
After deleting this file, macOS 13 Ventura should rebuild the configuration files for each of your Bluetooth devices. From there, you should try to add your Bluetooth device once again.
When all else fails
Hopefully, this article successfully reconnects your Bluetooth accessory to one of the best Macs, and your Bluetooth connectivity problems are no more. If you still can't connect a Bluetooth device to your Mac, it's time to contact technical support for the device. It's possible (for whatever reason) that the accessory doesn't work with Macs. However, it's also possible that the company behind your accessory has an easy fix, so check there as well.
Update September 2022: Checked steps for macOS 13 Ventura.
Most Popular
By Alex Blake
By Tammy Rogers
By Matt Evans
By Brady Snyder
