Deebot OZMO 930
Best answer: The ECOVACS Deebot OZMO 930 features Smart Navi technology that uses laser-based navigation scans to map areas to clean. In time, it adapts to your home, enabling more efficient cleaning.
What Smart Navi does
Thanks to Smart Navi mapping, the ECOVACS Deebot OZMO 930 can establish a cleaning pattern on the fly that's based on whether the machine is in vacuuming or mopping mode. When in the former, it can adjust the suction power automatically for deeper cleaning. During the moping mode, the technology will allow the robot to avoid carpeted areas.
But, there's more
Yes, you read right. The ECOVACS Deebot OZMO 930 isn't just a smart vacuum robot; it's also a mop. The company's OZMO products feature an electronically-controlled water pump that uses sensors to monitor water flow. By doing so, it offers a consistent cleaning result each time.
The ECOVACS Deebot OZMO 930 specifically also ships with interchangeable suction inlets and includes selective cleaning modes.
Save some money
If you're looking for an ECOVACS smart vacuum robot that features Smart Navi mapping but not the ability to mop, consider the Deebot 900. Priced much lower than the OZMO 930, the Deebot 900 has nearly identical features (without the moping capabilities) and comes in white, not black.
Buy one
All-in-one solution
The ECOVACS Deebot OZMO 930 works as both a vacuum cleaner and an automated mop; it's current ECOVACS' most feature-rich cleaning robot on the market in the U.S.
An alternative
ECOVACS Deebot 900
Lower price
The ECOVACS Deebot 900 offers most of the features of the Deebot OZMO 930, but for less. If mopping features aren't necessary, this is the Deebot robot to get.
