How to check the battery on your Poké Ball Plus
Instead of using the Joy-Con controller to catch 'em all, you can connect the much-cooler Poké Ball Plus to use as a controller with Pokémon Let's Go. The white button on top acts as a joystick and when you press it, it triggers the A button. The red button on top of the Poké Ball Plus launches your menu and exits out of windows. But how do you check how much battery life it has while you're out catching mons?
Products used in this guide
The Poké Ball Plus runs on rechargeable batteries, just like nearly every other electronic gadget these days. At some point, you're going to have to stop playing and recharge it using the included USB-C cable. But how do you know when it's time to put down your Switch and charge your Poké Ball Plus? Just like you would any other secondarily-connected controller.
Make sure your Poké Ball Plus is connected to your Pokémon Let's Go game (at this time, there doesn't appear to be a way to check your battery health with Pokémon GO on iPhone).
  1. Navigate to the Home screen on your Nintendo Switch.
  2. Select the Controller Settings.
  3. Check the section under Controllers. Here, your Poké Ball Plus will be listed with its current battery health.
Is it time to charge up?
How to get the most out of Pokémon Let's Go
If you really want to play Pokémon Let's Go in style, you're going to want to pick up a Poké Ball Plus. It's really fun to use instead of those boring old Joy-Cons. Am I right?
The Poké Ball Plus connects to your Nintendo Switch specifically so you can play Pokémon Let's Go (it currently doesn't work with any other games). You can "throw" your Poké Ball Plus, just like a pro and catch 'em all. It also works with Pokémon GO on your phone, so you're getting two gadgets in one!
Nintendo has reinvented the Pokémon story all over again. This time, exclusively on Nintendo Switch. You can travel between towns, catching Pokémon, talking to townsfolk, battling other trainers, and even earning Gym Badges. You can also sync up your Pokémon GO game and transfer all of those Kanto Region Pokémon you've been collecting into Pokémon Let's Go.
Lory Gil
