Does Apple's Smart Battery Case come with a charging cable?
Best answer: Apple's new Smart Battery Cases do not come with a charging cable, instead relying on Lightning cables or wireless chargers that you already have.Black: iPhone XS Smart Battery Case ($129)White: iPhone XS Smart Battery Case ($129)Pink Sand: iPhone XS Smart Battery CaseBlack: iPhone XS Max Smart Battery Case ($129)White: iPhone XS Max Smart Battery Case ($129)Pink Sand: iPhone XS Max Smart Battery CaseBlack: iPhone XR Smart Battery Case ($129)White: Phone XR Smart Battery Case ($129)
The Smart Battery Case is the only thing in the box
Since first launching the Smart Battery Case for the iPhone 6s, Apple hasn't included a charging cable in the box for the accessory, instead instructing customers to use the Lightning cable that came with their iPhone. This makes sense, as it saves Apple a little money, and if you have an iPhone, you'll have at least one charging cable.
You can also charge your Smart Battery Case faster by using a Lightning-to-USB-C cable plugged into Apple's USB-C Power Adapter, which can provide 18 or more watts of power.
Do you even need a charging cable?
The new Smart Battery Cases for the iPhone XR, iPhone XS, and iPhone XS Max all feature support for Qi wireless charging. This allows you to charge both your case and the iPhone in it at the same time. Just place your iPhone in its Smart Battery Case onto your wireless charger as you normally would, and you should be good to go.
iPhone XR
Keep your iPhone XR going and going
The Smart Battery Case adds to the iPhone XR's already impressive battery life, giving you up to 39 hours of talk time, 22 hours of internet use, and 27 hours of video playback.
iPhone XS
The power boost you need
Give your iPhone XS a battery boost with the Smart Battery Case, which extends your talk time to up to 33 hours, internet usage up to 21 hours, and video playback for up to 25 hours.
iPhone XS Max
Power for an already big battery
With the Smart Battery Case for the iPhone XS Max, you'll have more than enough power to get through your daily set of tasks, with up to 37 hours of talk time, 20 hours of internet use, and 25 hours of video playback.
iPad Air 6 in larger size ‘leaked’ by over-enthusiastic case manufacturer — ESR preps for the 12.9-inch model and new iPad Pro, ahead of rumored May launch
Apple's huge AI iPhone upgrade will be entirely on-device to start with — 'Full details' expected at WWDC 2024 with iOS 18 ahead of iPhone 16
This hidden iPhone feature puts your friends and family's locations directly into the Maps app using Find My
