So you have a new iPhone XS, and it's great! You have a top-notch phone with great and powerful new features, but your battery life could definitely be better. You find yourself having to charge up your device in the middle of the day to keep it going, or you end up toggling Low Power mode on to conserve that juice. Don't worry, with these great battery cases, your phone will remain charged and ready to go!
Great value
Trianium Atomic Pro Battery Case
If you're on a budget, then the Trianium Atomic Pro battery case is a great choice. It packs in 4000mAh in the battery, so you can get one additional full charge for your iPhone XS before plugging it in. And the bumper and shell design provides shock resistance for your device when those accidental drops happen.
$29 on Amazon
Magnetic mount
Vproof Battery Case
The Vproof battery case is a great option if you use a magnetic mount in your car or at home. The rather slim profile of this case manages to pack in a 6000mAh battery, so you can get about 150 percent more juice for your iPhone XS. There's also magnetic metal in the case itself, so it works with your existing magnetic car or desk mounts.
$25 on Amazon
Built-in wireless charging
Alpatronix BXX Battery Case
The Alpatronix BXX battery case is great for those who love wireless charging. This case comes packed with 4200mAh of extra juice, so you can get a little more than a full charge from it throughout the day. If you already have a wireless charging pad at home, just place the phone with this case on and both will charge like magic.
$50 on Amazon
Slim but powerful
Trswyop Battery Case
The Trswyop battery case somehow manages to fit in a 5200mAh battery in a super slim profile. This means you'll get almost two full charges for your iPhone XS before having to plug in, so this should be more than enough to get you through an entire day. Another benefit? You can charge this battery case with all of those existing Lightning cables laying around!
$28 on Amazon
Fun colors
MAXBEAR Portable Ultra Slim
The MAXBEAR Portable Ultra Slim case gives users a 4000mAh battery, so it should last you through the day before you need to plug in. The case is easy to install on your device and fits snugly, so it provides ample protection from everyday wear and tear. Plus, there are several bright and fun color options to choose from, so you can add some color to your device.
$31 on Amazon
Soft but protective
Newdery Battery Case
The Newdery battery case is another great budget-friendly option to consider. The case has a soft TPU frame so it's a bit more flexible than the others we've mentioned so far, but it still has a 6000mAh battery tucked away in a fairly slim profile. It also has magnetic metal in the back plate so that it works with magnetic car mounts.
$33 on Amazon
Trusted power
Ainope Battery Case
The Ainope battery case includes a 6000mAh battery stuffed into a super slim, 0.19 inch profile that weighs only 5.8 ounces. It's also certified by CE, FC, and RoHS, so there's nothing fake to worry about. The built-in smart security chip also protects your device from short-circuiting, overheating, and overcharging. There are also magnetic plates in the case itself so you can mount it on magnetic car mounts without additional knick-knacks.
$35 on Amazon
Apple Certified
ZeroLemon Slim Juicer Extended Battery Case
ZeroLemon is a brand that can be trusted, thanks to the Apple Certified connector. The battery case has 4000mAh, so you'll get enough juice to get through the day. The case is slim and provides good protection from bumps and drops. There are even safeguards in place to prevent your hardware from getting damaged from short circuiting and overcharging.
$30 on Amazon
Bulge-free
Feob Rechargeable Portable Power Charging Case
Many of the cases we've mentioned have a bulge on the back, which became popular after Apple's own Smart Battery Case release. However, Feob provides a sleek and uniform back with no bulge, so it looks like a regular case. It has a 5200mAh battery so you can double your iPhone XS battery life, without sacrificing good looks and slimness.
$35 on Amazon
Juiced-up shutterbug
Moment Battery Photo Case
If you love taking photos and video on your iPhone XS, then you need the Battery Photo Case. This slim (only adds 6.8mm thickness) battery pack case has 3800mAh of juice, so you do get enough to make it through most of the day. The soft TPU body means it's easy to install and take off if needed, and it has full support for Moment lenses. It has an electronic shutter button on the side of the case to replicate a real camera, and it works with the Moment App or iPhone Camera. You can even attach a strap and always be ready for spontaneous shots.
$99 at Moment
There you have it! These cases help you keep your iPhone XS charged to get through the entire day, and then some. I'd recommend the Trianium case because it packs in enough juice at a great price for the budget-friendly. If you can splurge, and love mobile photography, then the Moment Battery Photo Case is the way to go.
