Speck CandyShell Grip case for iPhone 6s review
Speck's CandyShell Grip Case is a sharp-looking case for your iPhone 6s with rubber ridges along the back.
Fit and finish
The pattern on the CandyShell Grip Case reaches up around the sides, ensuring that your iPhone 6s won't slip no matter how you're holding it. That rubber layer also provides baseline impact protection along the interior.
To top it all off is a hard plastic casing that has enough flexibility to permit installation while still giving some scratch protection to the rubber. As for input access, you have big chunky passthrough buttons for the power and volume keys, while opening for headphones, Lightning adapter, speaker, mute switch, and camera are there. The headphone jack has a little bit of extra room to accommodate a variety of 3.5 mm plugs.
Speck earns extra points for offering this case in so many colors. I'm digging the black and white myself, but no matter which color of iPhone you ended up owning, you'll easily find something that suits your style. As for sheer impact protection, I've been perfectly happy with what the CandyShell Grip offers. The extra raised lip around the front face adds a lot of confidence.
The worst thing I could say about the CandyShell Grip case is that it fits the iPhone 6s almost too snugly. It takes a fair bit of force to push just one corner through the camera gap, and even that's not enough to fully push the iPhone out. You'll still need to do some prying on the other corners to be set. That said, you certainly don't have to worry about your case accidentally slipping off; the Speck CandyShell Grip is extremely secure.
Bottom line
The two main selling points here are the extra grip afforded by the rubber backing and the wide range of color schemes available. Models for the iPhone 6s and 6s Plus are available, and they're confirmed as compatible for the previous generation of iPhones. If those are high priorities, go and snag one of these. You won't regret it.
$35 at Amazon
Simon Sage
