Mac Help: Sharing files between users on the same Mac
Welcome to Mac Help, our new column focused on helping you, the reader, with troubles you're having on your Mac. This installment's question comes from Doug Larsen, who needs help sharing files between his and his wife's user accounts on their family Mac.
Dough writes:
There is an equivalent to the Public folders feature in Windows, but it's pretty well hidden. For whatever reason, Apple doesn't make it very easy to use. Fortunately it's not difficult to set up.
First of all, setting up different user accounts on the same Mac is a great way to keep things organized, and I wish more people would do it. You share the same applications and system files, but your individual settings and your documents are completely different. It's an efficient and productive way to let more than one person use the same Mac. So kudos, Doug, on doing the right thing.
If you check your /Users directory, you should see a folder called "Shared." That folder is dedicated to shared files that can be managed between different user accounts. A few of the applications I've installed use it so they can run without any trouble regardless of which user account is active, but you can use it for whatever you wish.
To access the Shared folder, simply open the Finder and select the Go menu, then select Go to folder... (or type command-shift-G). Then type /Users and hit return.
You should be staring at the list of user folders on your Mac, with a Shared folder there as well. If you'd like to make it easier to access, simply drag that Shared folder into the Favorites sidebar on the left of your Finder window, or (as I pointed out in last week's column), command-drag it to the Finder toolbar if you'd prefer to have it on the top.
Either way you'll be able to access the Shared folder instantly, so you and your wife can both have access to common files you need. Whoever created the file will retain ownership of it, so the second person will need to make a copy of it and edit the copy.
Another way to do it is to use a third-party sync tool like Dropbox, but that requires you to upload and download the file using the Internet. This way the file stays local only on your Mac, which could be an important consideration if security (or bandwidth conservation) is paramount.
Got a question? Send it to machelp@imore.com. If you need help with your iOS device, send a question to ioshelp@imore.com.
Most Popular
By Alex Blake
By Tammy Rogers
By Matt Evans
By Brady Snyder
