What are the best battery cases available for the iPhone 7?
Updated March, 2017: Added BoxLegend and Alpatronix to the list
The iPhone 7 is one of the coolest tech toys to come out least year, but want to know what's not cool?
Your battery dying before noon. CUE DRAMATIC MUSIC
Luckily for all of us who love to use our phones constantly, there's a simple solution to keeping your iPhone 7 charged and always ready to go: a battery case!
Here are a number of reliable battery case options to browse through if you're looking for the perfect power-up for your iPhone 7!
iPhone 7 Smart Battery Case
If you're looking for the ideal battery-rific partner to go with your iPhone, then why not head straight to the source and check out Apple's iPhone 7 Smart Battery Case?
Engineered exclusively for iPhone 7, the Smart Battery Case gives you even longer battery life while offering great protection.
Designed with a soft microfibre lining on the inside, and a smooth silicone exterior, the iPhone 7 Smart Battery Case increases your talk time up to 26 hours, and your internet use up to 22 hours. Plus, it worked seamlessly with your iPhone 7, displaying the case's power status on your iPhone's screen so you know precisely how much charge is left!
The case doesn't come in a huge variety of colors, but you can pick from an incredibly sleek white, black, or (RED) case for around $129.
See at Apple
Trianium Atomic Pro iPhone 7 Case
With nearly 200 5-star reviews on Amazon, the Trianium Atomic Pro iPhone 7 Case Battery Charger is a powerful little backup battery to consider pairing with your iPhone 7.
Designed with a protective, 360 degree bumper case, and able to charge your iPhone with the push of a button, this protective battery case will add an additional 14+ hours of talk time or nearly 10+ hours of web browsing time to your iPhone 7's battery life.
Unlike plenty of other battery cases, the Trianium Atomic Pro is actually quite slim and compact (though it's definitely not designed to be ultra-thin and minimalist). You can pick up this particular battery case in white/turquoise, white/grey, black/burnt orange, and classic black.
See at Amazon
Maxdara Charging Case iPhone 7
If you're looking for a case that'll add over 15 hours of talk time to your battery life while still protecting your iPhone from scratches, falls, and accidents, then take a peek at the Maxdara Charging Case iPhone 7.
After sliding your iPhone 7 into the Maxdara, you'll instantly add 17+ hours of talk time, or a whopping 10+ hours of additional app-use time to your iPhone's battery. On top of that, one more unique feature the Maxdara has is its power-level indicator using 4 multicolored LED lights that let you know when you're runnin' out of juice.
While most battery cases come in a small handful of colors, the Maxdara Charging Case comes in over six, including black, blue, gold, pink, silver, white, and rose gold (plus, for only $32.99, why not check it out?!)
See at Amazon
Mophie Juice Pack Air
Mophie's Juice Pack Air case has been a favorite for years, but now there's an option for your iPhone 7: and with Mophie's excellent product design, it's a good bet you'll <3 it for your iPhone 7, too!
Not only does the Mophie Juice Pack Air keep your iPhone 7's battery alive for an additional 27 hours (say whaaaaaaa?!) but it also has the ability to charge wirelessly with one of Mophie's chargers. That means you no longer would have to worry about hauling lightning cables around with you! Or replacing them when they fray and die!
This sleek and sharp case may not be the thinnest, but it looks and pairs perfectly with the iPhone 7's aesthetic and feel. You can pick up the Mophie Juice Pack Air in four colors, including black, rose gold, navy blue, and (RED).
See at Mophie
BoxLegend iPhone 7 battery case
The BoxLegend case promises to pack quite a power-punch: after you slide in your iPhone 7, you'll get up to an additional 92 hours of music or 27 hours of talk time, along with 16 hours of extra app use. It takes around 2 and a half hours to fully charge your iPhone 7 once it's dead, though.
Great case, especially for the price. Very thin it won't add a lot of bulk of weight to the phone compared to cheaper models. The material feels very good and the lights in the back work very well. You can simultaneously charge the phone and charger at the same time which is a plus. This case will double your battery life. Overall exceeded expectation! [sic] (Amazon user @Morris Manis)
This fairly thin, 0.51-inch case may not be the most protective option for your iPhone 7, but it is a wonderful option if you're looking to squeeze a little extra juice out of your tech. The BoxLegend case comes in only two colors: rose gold and black.
See at Amazon
Alpatronix BX170 Ultra-Slim charging case
If you're looking for a reliable battery case that won't add a terrible amount of bulk to your iPhone 7, while still being able to (almost) perfectly match any iPhone color, then check out the BX170 Ultra-Slim charging case from Alpatronix!
This is our favorite slim battery case right now for the iPhone 7 and 7 Plus... the Alpatronix BX170 Ultra-Slim iPhone 7 Battery Case. [sic] (Marena Estrada, BGR)
Apple-certified, designed with a scratch guard, as well as a raised bezel in case you drop it face-down on the ground and super-duper easy to install, the Alpatronix BX170 Ultra-Slim charging case is an incredibly well-designed and durable battery pack for your iPhone.
One downside? The Alpatronix BX170 Ultra-Slim charging case case doesn't work with Apple's EarPods or with a Lightning cable or traditional 3.5mm headphones – it's only compatible with any wireless Bluetooth headphones or Apple AirPods, since it takes up the Lightning port on your iPhone. #sadtrombone
That being said, the BX170 is relatively affordable (around $50) and comes in colors that perfectly match your iPhone 7! Well, unless you have a space gray one...
See at Amazon
What's your pick?
Is there a battery case that you're absolutely obsessed with? If so, let us you know favorites in the comments below!
